After having a few quiet months without doing anything on my lovely red truck (except the odd tinkering when you need to get away from the mrs) I decided to finally reconnect my new dual batteries up and try to start the engine. Firstly might I add that if you do happen to own a supra 2jzgte then you might want to have the custom made exhaust on the truck before you start, especially as my ears started bleeding. No exhaust from the manifold will do that to the mortal man.
My question is that my 4 wheel drive light is on. without the button being pressed or in low box. So i turned the hubs round numerous times as it's on axel stands with no wheels at the moment, and still wouldn't disengage. Does anyone have any ideas why?
I was under the impression that you needed power to the four wheel drive system to engage it, but i have not had any batteries on it for at least two months. I'm probably wrong though.
cheers
cheers
