g'day folks. i am new to this, but, just bought a 91 ssr limited 2.4lt turbo diesel. it overheated in january apparently and had all new top end put now the diesel pump is literally teeming diesel out when motor is running and for a few minutes after shutdown. i have tried to see where leak is coming from but can only see where it is running down block and over sump. when on h/way it is throwing diesel all under vehicle and up onto rear of car. also the engine check light on dash comes on when you turn on ignition then goes out and comes back on again and stays on while engine is running.
can anyone tell me
1- is the check light because of the leak
2- how to ascertain where leak is coming from and if i need to remove complete pump to renew seals.
it also has a suspension switch on the console with normal or hard. when switched to hard are you supposed to notice a considerable change and should a light come on dash to indicate this.
thanks to anyone who can help.
regards
bryan
can anyone tell me
regards
bryan
