Quick question, chaps...
I sheared the bolt that keeps the power steering belt tensioner in place.
In order to replace it, would one need to remove any part of the air-con system? Even if you have to remove the power steering pump, surely the air-con remains untouched?
I can't believe that Toyota would have designed the engine bay in such a way that you'd need to remove (and thus re-gas) the air-con in order to simply change the steering pump.
