Just bought this and when I switch a/c on their is no increase/decrease in revs and no cold air ..also the front fan (one behind the bumper) does not turn. anyone have any ideas ? is it the compressor or could it be a blown relay? any sugestions welcome thanx
Air Con 93 2.4 ssrx
if it's an auto, the aircon has a pair of fans under the engine above the aircon rad. The quickest way to check is to look at the aircon compressor with the engine running, the pulley centre part is stationary with air con off, switch aircon on (button lights up green) and the centre part turns with the outer pulley. (does that make sense?) if the compressor is ok, check the sight glass on the metal pipe from the aircon compressor (it's near the front grill off centre toward the passenger side), if it is bubbling, or you can see fluid, then you need a recharge, if there is no fluid, then you could possibly have a leak, either way, you need an aircon specialist.[COLOR=red]Simon [/COLOR] '91 2.4td ssr-x
the small fan in front of the rad is just for additional cooling for the engine rad, although i don't think anybody in this country has ever seen it kick in.
if the compressor is not activating, (is the aircon button lighting up?) i'd check the fuse, although i'm unsure which one it is, i'll dig out my max ellory manual and see if i can see it in there.[COLOR=red]Simon [/COLOR] '91 2.4td ssr-x
