Hi, I wonder if anyone can help me please? I have a 1992 2.4 diesel Surf which I have owned for about a month & am thoroughly impressed with. Yesterday in the rain all my dash warning lights illuminated (a/t fluid, timing belt, battery, diesel filter, turbo light) accompanied with an alarming constant beeeeep. The car runs & drives as normal but its driving me crazy. I have had the instrument panel out, disconnected the batteries to no avail. I'm assuming water has got in somewhere but after being dry all day it is still doing it. Is there some kind of control box or connection somewhere that could be causing it? Thanks for taking the time to read my first post : )
All Warning Lights On & Warning Beep - Help!
Thanks guys, I will try that tomorrow. To add to it, when I go sharp around a corner it all goes back to normal for a few seconds but then its back to doing it again. I will belt it very hard & hope for the best tomorrow! Could it be the rain or was that just coincedence? Thanks again for taking the time to reply - Darren : )
Originally posted by igot1ofthem! View PostThanks guys, I will try that tomorrow. To add to it, when I go sharp around a corner it all goes back to normal for a few seconds but then its back to doing it again. I will belt it very hard & hope for the best tomorrow! Could it be the rain or was that just coincedence? Thanks again for taking the time to reply - Darren : )' You've arrived on a rather special night. It's one of the master's affairs.'
Alternatooor!
Thanks guys, yes I believe it to be the alternator as I lost charge yesterday. Hope that helps anyone else with the same prob! I just ordered one from ebay so hopefully will sort the problem with this otherwise superb truck. I moved from a SWB Shogun over to a Surf & other than this hiccup am very happy I did so. I regularly tow dead shoguns off to their final resting place & the Surf does it with so much more grace & indeed pace : ) The only other bit I need is the trim cover over the rear chrome bumper if anyone has one?
Originally posted by igot1ofthem! View PostThanks guys, yes I believe it to be the alternator as I lost charge yesterday. Hope that helps anyone else with the same prob! I just ordered one from ebay so hopefully will sort the problem with this otherwise superb truck. I moved from a SWB Shogun over to a Surf & other than this hiccup am very happy I did so. I regularly tow dead shoguns off to their final resting place & the Surf does it with so much more grace & indeed pace : ) The only other bit I need is the trim cover over the rear chrome bumper if anyone has one?' You've arrived on a rather special night. It's one of the master's affairs.'
Originally posted by igot1ofthem! View PostHi, I wonder if anyone can help me please? I have a 1992 2.4 diesel Surf which I have owned for about a month & am thoroughly impressed with. Yesterday in the rain all my dash warning lights illuminated (a/t fluid, timing belt, battery, diesel filter, turbo light) accompanied with an alarming constant beeeeep. The car runs & drives as normal but its driving me crazy. I have had the instrument panel out, disconnected the batteries to no avail. I'm assuming water has got in somewhere but after being dry all day it is still doing it. Is there some kind of control box or connection somewhere that could be causing it? Thanks for taking the time to read my first post : )Happy Surfing!
