Ok so mentioned in another thread I when i brake it pulld slightly to the left. so i need to strip down the caliper and clean. I`ve haveged the pads before but not sure about this so....
a. how do you get the caliper off?
b. will i loose all my brake fluid?
c. is it worth getting one of these and changing the fluid while i`m at it? http://cgi.ebay.co.uk/Eezibleed-Kit-...QQcmdZViewItem
c. is it an easy job to relplace the brake lines for the braded roughtrax ones?
Thank you all!!
Thank you all!!
