STORMFORCE 0r anyone
hi mate can i drive with a bit of oil i think is coming out of the turbo pipes underneath will it do any damage apart from losing oil as ive rounded one of the nuts off the 1 its hard to get at will i just lose a bit of oil or wat plus im towing caravan 2 perran sands newquay next week from manchester is there any thing i can put in to slow it down any ideas mate.
NEVER GIVE UP SHES WORTH IT*Tags: None
if its not peeing out then it should be ok till you get back.I don't think there is anything that can be put in to stop it from leaking.Just keep an eye on the oil level over the next few days and see if it drops a great deal or not.Unfortunately i am back to work next week or i would of offered to take a llok for you while you are down herehttps://www.facebook.com/groups/henpals/
The only other way to get it off and thats to take the manifold ect off to get the turbo out and then take the pipes off.If you can get the bolt/nut out then Toyota should be able to get you another for a couple of ££'s unless someone else has got one the right size lying about you can havehttps://www.facebook.com/groups/henpals/
