I've had the fuel pump fitted with new seals by a reputable company mentioned on this forum, and I've re-installed the pump, but with everthing back together I can't get it started. It turns over but there's no attempt to fire up.
I don't understand how the injectors work, I can see that fuel is getting to the top of the injectors because I've had several leaks from the top connections. So I'm wondering if it's an electrical fault, maybe a cable could have fractured whilst they were moved around, or maybe I've not put something back correctly. I assume the injectors are opened electrically at just the correct time. There's an electrical connection that is in the middle of the 4 injectors and it connects to what looks like an earth bar.
The other thing I was wondering about is how critical is the rotated position of the pump; I've aligned it to the scribe mark, but how accurate does this have to be, what if it was 1mm out?
Can anyone advise please?
u beat me.....
