Hi everyone, i've been reading through this site for a week or two now and have just signed up. I'm really really hoping someone here can give me some advice on how to go about correcting a major problem i have with my new car.
A month ago i bought a 1992 surf, 2.4lt TD. the thing's pretty much immaculate and the only problem i am having with it is a doozy.
It drives absolutely beautifully on level/flat ground, but the moment it is under load...i.e towing even an empty trailer on relatively level ground, heading up even a slight hill or every now and then, just for the hell of it as it appears its little red light comes on and kills me.
It will be driving beautifully then all of a sudden seems like it's surging a little then the red check light comes on and looses all power - have read this is called "fail-safe" mode??
i can then pull over, take it out of gear, the red light then dissapears and i can take off again as though nothings wrong, but only lasts a few metres then it starts all over again.
The most annoying thing is i have taken it to a mechanics twice now but they just can't work it out. I have jumped the terminals on the ECU and have been given two codes - code (8) - apparently the "air intake temp sensor", and code (12) - apparently the "knock sensor". I have tried disconnecting the air temp sensor, but to no avail, put a brand new fuel pump, air filter, oil filter, all fluids, but no matter what i do it still does it.
I have been told it could be a few things - turbo pressure sensor, fuel pump, injectors, blah blah blah...but to be honest, if two different mechanics couldn't find it, my deisel mechanic friend cant work it out, the people on other sites can't work it out, it is just plain and simply driving me insane.
The real bad thing about this all is i just got rid of a '76 hilux tray top with a 2.4lt v8 petrol put in it, got rid of it coz i just wanted a newer modern reliable car, but now i can't even make it up the hill to get home.
I would appreciate any help on this more than i can say, and really hope someone has some ideas or has come across a similar problem and solved it.
Thanks a heap in advance,
Davo
Davo
