ive had head rebuilt new glowplugs,new glowplug recister,new valvle pump,ecu fitted still wont start help please heeeeeelp heads going legs chopped off dying cant afford much moreps 2.4tdi 2l-te/surf on93 plate
i Take it all the leads are connected...? You may think its silly but it could be as simple as a lead hiding under there in the shadows...!! I'm assuming you've bled the fuel through....?
Always assume the worst.....Anything less is a bonus!!
all leads are connected doing my head in mate cheked round for lose wires none insight
speedy this is why i went out bought plugs aglow plug recister pump valve even a ecu had plugs tested ok pump valve workig timing spot on ive done everything i know now
so let me get this right so i can have a think...
You turn the key.... the engine turns over and keeps turning over but will not start...? And there is fuel coming out of the injectors when you crack the bolts open..?
