Hi all.
I have a little prob with the rear window.
When I press the switch for the window (to go down) you can hear the mechanism
working and the glass sliders down a tinny amount, but then the glass stops but the mechanism goes down about 2inches more and then stops, I then go to the back and push the glass down to where the mechanism and repeat this over and over until the window is down.
I then have to do the same going back up but it’s slightly trickier when it gets to the seals at the top.
I have tried greasing up all of the mechanisms and looking the seals around the window frame, but this did nothing.
Hopefully one you can help.
Many thanks will
Many thanks will
