During coolant change, I was struggling to get to bottom hose and drain valve on bottom of rad, so needed to drop air con rad / fans. Still a bit tight, so like a t*at undone the nut that holds the 2 'figure of 8 shaped' rubber blocks together which prompted an immediate high pressure release of I'm guessing air con gas?? After changing the boxer shorts, re-done nut up and left well alone. 2 questions guys:
1) It is just air con gas? (hoping its not the deadly Jap version and I've just killed my whole village)
2) Is it a case of just getting air con re-gassed and all will be well?
Any help appreciated.
