I have been struggleing to undo the crank pully bolt on my 2.4lte motor for a few days.
I tried all mannor of M8 bolt and bar combinations to no avail. I got in an industrial compressor for the my air gun and that still didnt work.
So i cut the cam belt and carried on with the head replacement.
I managed to undo the pully bolt by using two head bolts and a stip of 5mm steel. Fit the head bolts accross cyl 1 and drill the steel to match.
Use a block to wood large enough to spred the load accross the piston, i used a fresh bit of tree that was perfect size for the cyl. Place the wood in the cyl so that the piston contacts it about 3/4 the way up its compression stroke and as its stopped by the metal strip bobs your uncle.
My bolt was really stiff and covered in thred locking gue but was a sinch to undo this way.
Hope this is useful
Regards Andy
Hope this is useful
Regards Andy
