So if its the rad that has blown then i have a rad less then a year old for if your interested.I would also change the old hose clips for some decent jubilee clips also.
The first breaker i had a few weeks ago the guy carried on driving the truck although he knew it was losing coolant and it was where the top rad hose outlet is welded to the rad which had come away and in the end he blew the head.This sounds as if its the same place as yours has gone so you may well be lucky and get away with not blowing the head by stopping almost straight away.Get the rad replaced and then get the head pressure tested aswell then you'll know if the head has gone.If the garage repair it then ideal but if you got to do it then your looking at about £1200 to £1400 i would say for repairs
