...which is easy enough, however I saw a Brake Pad Pin Fitting Kit on Roughtrax and was wondering if I need to buy that as well, or is just something they're trying to make an extra tenner with? I've always (on previous cars) kept and re-used the original gubbins; is the Surf not the same?
Brake pads need changing...
Buy the kit. I destroyed mine when removing the pads.Originally posted by MadcapMagician View Post...which is easy enough, however I saw a Brake Pad Pin Fitting Kit on Roughtrax and was wondering if I need to buy that as well, or is just something they're trying to make an extra tenner with? I've always (on previous cars) kept and re-used the original gubbins; is the Surf not the same?
When you re-fit everything, use copperslip on the pins to stop them siezing.Do you know that, with a 50 character limit, it's
