As the title says i am getting plooms of bluey white smoke coming out of the exhaust and the engine is running rough between 2000 & 3500 rpm, i've always had smoke when starting from cold but a quick blast on the accelorator and its all gone.
The oil is fine (just been changed) and the water is fine (no loss or no oil in it), the only other thing different is the exhaust is blowing from just after the turbo.
Could this be fuel starvation or a blocked injector, would this cause the smoke??
