i know i dont need it right now but i wanna know it will be working by summer so here goes, i press my air con button and nothing happens, the pulley on the pump just freewheels, can i put a multimeter on the pumps connection to see if it has a feed and if it does then whats the problem likely to be and if it doesn't whats the prob likely to be? cheerz boys and girls.
Air con
Put 12v to the compressor to test the clutch, if the gas is low, the ECU won't let power getto the compressor.Originally posted by YoungOffroader View Posti know i dont need it right now but i wanna know it will be working by summer so here goes, i press my air con button and nothing happens, the pulley on the pump just freewheels, can i put a multimeter on the pumps connection to see if it has a feed and if it does then whats the problem likely to be and if it doesn't whats the prob likely to be? cheerz boys and girls.
If the clutch is OK, 9 time out of 10 it needs regassing.
If it has gas, check the fuses behind the glove box.4x4toys.co.uk - Keeping you on and off the road...
The switch does light up and the fan was on, theres some gas in it cos i stuck the end of a pen in the valve thingy n got a face full. one of my neighbours is an aircon specialist n i helped his daughter once and he said i can always have free gas, before i knew he done air con though i fort he was offering me diesel! i havent got any batteries on the truck at the moment but should have it all working by mid week so i shall try it all then, cheerzSurfin on the tidal waves of mud!
disco now gone aswell
