My turbo is not working, the boost light works untill the engine is warm then nothing.
and i cannot hear the usual whurring and there is No power.
all the lines are attached and appear to be ok,
this has only reasontly happened, i have looked at the tech site and it is of no help,
i have no way of checking pressure, other than the first pipe has suction i cannot trace any further along,
i do not know if the sucktion continues through all the lines or if it stops at a valve when idleing,
obviously getting the turbo to kick in when the car is not moving is not an option.
no idea where to go from here
Red line shows pipe with suction and direction its sucking in, where it goes into the sensor appears to dead end (i dont know if its ment to continue through other pipe on the sensor or not, there is no detectable air flow through any other line When the engine is idleing anyway
Have just noticed when the engine has been off a while the boost light works as normal for a short while, (altho i dont know if the turbo is acctualy working but i dont think so) then it stays off and the engine check light comes on.
