Chaps
Not the usual question regarding rear windows so bear with me, replaced the motor etc and goes up un down but seem to have done something wrong as the large handle that realeases the tailgate turns the plate that the rod attaches too but doesnt rotate the plate that the release cables are on, to make matters worse and for no apparent reason the small lock button on the tailgate that you pull up to unlock tailgate is stuck down even with its actuator rod in a free position.
Anyone else had this problem when refitting the mechanism and secondly how do you get the grey trim panel off that the realease handle is in as I have removed all screws that I can see.
Cheers Steve
Cheers Steve
