PLEASE,PLEASE HELP. MY SURF HAS NOW BEEN OF THE ROAD FOR 6 WEEKS AFTER CRACKING THE HEAD AND THE BLOCK, OUCH!!!!!!!! I HAVE BOUGHT AND HAD FITTED A RECON ENGINE WHICH RUNS AS SWEET AS A NUT, BUT AFTER ABOUT 2 MINUTES THE WATER SYSTEM STARTS TO BUILD PRESSURE AND BLOW WATER OUT. WE HAVE TRIED EVERYTHING, GAS CHECKING THE WATER SYSTEM, NO EXHAUST GASES. THE ENGINE IS NOW RUNNING WITH JUST THE RAD AND WATER PUMP CONNECTED, ALL OTHER WATER SYSTEMS HAVE BEEN ISOLATED TO TRY AND ELIMINATE THEM AS THE CAUSE. STILL PRESSURIZING. CAN ANYONE OUT THERE IN SURF LAND HELP? THANKS YOU GUYS.
