hi all. i'm new to the world of surf's, but had a lucky escape on sunday. while driving home a strange rattle/vibration started coming from the engine at low revs. stopped and checked, nothing!! so did the only thing i could think off! booted it all the way home(4miles).this morning checked heat shields,exhaust etc. finally found it,fuel pump was loose,1 nut missing, 1 loose.the missing 1 was the 1 between the pump and block, a real joy to replace.the engine is running ok (possibly pinking under load). 2 questions. 1:if i have to set pump timing, how?? 2: how do i slacken and tighten that fu**ing nut and retain some skin on my knuckles
? cheers
