Hi folks, I wonder if you can help me, I have a 3 core radiator fitted in my 2.4 LN130, it has started to leak a bit, so bought a new 2 core radiator, when I hitched my caravan on it over heated going up hill which it never did with the old 3 core one. Does anyone know where I can buy a new 3 core radiator?
Radiator problems
Thanks guys but Milners only stock 2 core, they say you cannot get
a 3 core but I saw one on e bay from a shop ages ago and of course now I want one I cant find them.
I will give Roughtrax a call. but if you have anymore thoughts let me know
thankx.
Donmadave
at a guess the seller on ebay would have been iezuraparts they've been mentioned a few times on here, but never really heard any feedback on them (good/bad)
http://stores.ebay.co.uk/iezura can't see a 2.4 rad on there atm though - that maybe coz i can't be arsed to look though=========
=SOLD UP!=
Thanks have beeen on their site and they have a 3 core one, hopefully this will solve my overheating problems when towing.Originally posted by nero279 View Postat a guess the seller on ebay would have been iezuraparts they've been mentioned a few times on here, but never really heard any feedback on them (good/bad)
If you do a lot of towing, it's worth fitting a transmission cooler, as the one built into the rad can't cope and the heat is transfered to the engine coolant causing overheating.Originally posted by donmadave View PostThanks have beeen on their site and they have a 3 core one, hopefully this will solve my overheating problems when towing.
Totally agree.Originally posted by BUSHWHACKER View PostIf you do a lot of towing, it's worth fitting a transmission cooler, as the one built into the rad can't cope and the heat is transfered to the engine coolant causing overheating.
When off roading my aux fan always kicked in due to conditions - low speed and high revs.
Since fitting tranny cooler the fan has not been heard - and I 've checked that it is working as it should.
Shows how much heat the tranny dumps into the coolant.Another member of the 'A' team
also there was a design fault with the auto rads the gearbox cooler blocks the bottom rad outlet have a look next time you have one offOriginally posted by The Lovely Boyo View PostTotally agree.
Shows how much heat the tranny dumps into the coolant.JAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
