Been trying to diagnose a problem with my gearbox. I found this thread on the Australian site http://www.toyotasurf.asn.au/forum/v...gnostics#90020
I started to follow what was suggested in the 10th post. I don't seem to have any voltage at all at the W terminal (it actually doesn't fel like there's any connector in there), is this OK on a 2L-TE or have I possibly found my problem? Is there any other way to check the TPS voltages?
If it's still doing it then, I'd check the connections to the gearbox sensors on the gearbox itself. There are two or three on there, if I remember correctly. Could just be a corroded/damaged wire.
