Hello and thanks for the help on my alarm,,,,next problem is my 4wd dash cluster light,,, i click the 4wd button on the stick and the solenoid clicks,i lay under the front diff and when the same switch was activated i could here the diff being activated,ie moving in then outonce the 4wd button is depresed again,while doing a road test to see if 4wd was working only in a staight line on tarmac( I am aware of diff lock ,w/up problems etc),all seemed well apart from NO DASHBOARD LIGHTS illuminating,,,,,,I KNOW YOU GUYS N GALS ARE GOOD SO COME ON ,,,TELL ME THE FIX,,PLS
