Rear fog wiring
  • Rear fog wiring
    Hi all
    Failed on the rear fog light. Old light was shot s bought a new one, traced wiring back to under dash and looks pretty comical!!
    It has been wired with a relay and inline fuse, power from ignition lead with inline fuse to relay, power from what looks like a headlight wire to switch, 2 earths coming off relay on a dual connector, 1 going to switch and 1 going to body, 1 wire coming from relay to rear fog lamp and 1 wire going from switch to relay.
    Now im not an auto electrican so I have just tested the basics, got 11.85v at the light, the switch and the relay but dont seem to have any power.
    Could someone shed some light and possibly a diagram as to how this should be wired up???
    Many thanks
    The Badger
    what you explain sounds about right to me,
    take it there's an earth on the foglight?
    =SOLD UP!=
      Originally posted by The Badger View Post
      Hi all
      Many thanks
      The Badger
      All I did for mine was run a wire from a live under the dash, put a fuse and switch in it, then ran it to the foglight and earth from light to body..
      Worked fine for me and took about 15 mins
      Paranoid? They're out to GET YOU!
        Run a wire from the dash lighting circuit to a switch (switch must have a warning light when it's switched on btw), then from the switch to pin 85 on the relay, then a wire from pin 86 on relay to earth. This will turn the relay on and off, and only work when your lights are on.
        Run a fused wire from the battery into pin 87 on the relay. then run a wire from pin 30 on the relay to the foglight. Then run an earth from the fog to chassis.
        Rob.
