Crank seal
  • Crank seal
    Well stripped it down today .........the oil is from the crank seal.
    cannot feel any play , no bottom end noises , so still wondering why it's gone 18 months after being replaced . will check the shape of it when i get it out tomorrow .............................. .
    www.daemon4x4.org
    find that hard to believe with your reputation
    =SOLD UP!=
      And there i was expecting a sensible answer in this section
      www.daemon4x4.org
        my bad
        Looks like your crank oil seals leaking to me mate
        =SOLD UP!=
          my bad
          what i am worried about is the bearings are on the way out
          www.daemon4x4.org
            Decision time
            Right i cannot find any play in thebearing ...the seal does not look out of shape
            So do i keep looking or stick in another seal and hope i had some bad luck.
            And yes vince thats the cleanest its been since i got it
            www.daemon4x4.org
              Hi Ian,
              I've changed Hilux timing belts a couple of times so I have no worries about stripping it all and doing the seal.
              How long did the job take, and how did you get the seal out - coz mine has deffo gone and needs sorting.
              cheers
                Originally posted by The Lovely Boyo
                Hi Ian,
                cheers
                The seal just hooks out .......it's about a 20 min job ontop of the belt .
                http://www.toyotahilux.com/?doc=16&cid=610&vid=157
                Getting a new cam belt cover seal as well as it looks like it got full in there
                http://www.toyotahilux.com/?doc=16&cid=605&vid=719
                Pulling the injector pump as well and putting in vince's old one
                I have bits off bushwhackers , jotto's and the Bullit now
                www.daemon4x4.org
                  OK - cheers
                  I'll get the seal and give it go.
                    [QUOTE=Woodzie]Right i cannot find any play in thebearing ...the seal does not look out of shape
                    So do i keep looking or stick in another seal and hope i had some bad luck.QUOTE]
                    Replace the seal with a new one anyway as it would be rude not to.
                    Does the old seal feel hard and/or brittle? maybe your engine oil got hot and cooked it causing the leak.
                      Replace with a Genuine 90311-42026 seal. Looks like you have the black rubber seal. Was it a genuine seal? The 90311-42026 is a Viton seal and may solve the problem. Make sure you check the crank where seal is for any scoring. If it is scored it will destroy any seal.
                        i used to always have trouble getting those seals in. they never sat right for me, and most of the time leaked. pain in the bum! but thats fords for you
                        Oh Nana, what's my name?
