Hello,
I'm working on my mates Hilux pickup - 2.4diesel 1992 solid front axle. It has a lot of play on the front nearside wheel bearing. I've already dismantled my hubs serveral times so I know how to get those off.
These AISIN manual hubs have me stumped. I have read this article - http://toyotasurf.asn.au/techsite/hubs.htm
I have taken the front cover off - the 12mm bolt in the centre of the drive shaft is missing.
Do I need to dismantle the manual hub (circlip is a right bugg3r to get to)????
The cone washers are solid - wd40, heat, BFH - you name it - I've tried it.
