also would this stop it from starting if they were knackered
Nah, unless its leaking, but then you'd see fuel around the filter. Only the winter trucks have them, it should start fine without it working. THe pump its self may be knackered though, like I said on the phone, Linda's truck takes an age to start after doing the filter and the pump diaphram is knackered.
As for have I got one....
Yup, but no, you can't have it, its for Linda's truck to replace hers, and to help heat the veg oil.
ok if i put on a differant primer one without the sensors on will it work ok, and fire it up, as i have one and tryed it, and it pumps solid
cheers if i get anymore probs with it i'll give you a bell. and if poss any chance you can have a look at it as i got the xmas run to do, so need it up and running
cheers
no wasnt thinking that m8 nigel said a small piece of dirt can stop it getting through if it gets blocked? was wondering if it the same block from fuel tank n need a blast of air? or perhaps the filter was $$$$
