Hello, I have a Surf with problems.
It has just had a new head fitted due to engine overheating, at the same time it had injectors recon'd, new water pump, new thermostat, new pressure cap, new rad and even new hoses. The problem now is it will only go around 1 or 2 miles before it starts to get hot,the rad top hose goes very hard and it also fills the expansion tank to the top but not over flowing,the turbo is getting rather hot aswell ( to the point theres smoke coming from it) . I have tried it with 2 different pressure cap's, ive tried it without the thermostat in and i have made sure there are no airlocks in the system but it is just the same. I was told it maybe a cracked block ????? Does anyone have any ideas ?
OH!! And it will sit quite happy ticking over all day but as soon as you drive it down the road,Wak Wak oops. Thanks Dave.
