Since changing back to standerd rims i can feel a slight vibration through the steering wheel. When i jack the front up there is slight play on the nearside wheel if i push/pull top and bottom. Is there any adjustments that can be done or will it be the bearing??????????
Cheers.
Cheers.
I'll have a wee look at tmrw after work. Check and see if my calipers are still there while i'm at it!!!
) and thats it. Got a 55mm socket from the workshop at work this morning. Makes a change having the right tool for a job!!!! The nut was quite loose and took a quater turn before any resistance. Disc still moves
