Do Me A Favoure, Help With Turbo
  • #16
    Originally posted by surfenstein
    right so its non efi and wont have a sensor.
    The 89-90 mech fuel pump trucks still have the sensor, but not sure if you lose the same power without it working as the EFI trucks do.
    Have a look here....
    http://toyotasurf.asn.au/techsite/turboboostfix.htm
    • #17
      yer that's right. i managed to re-wire the old one back in, but then the engine would cut out unless i gave it some gas, witch is probably why the previous owner wriped it off. in the 1st place.
      • #18
        in case you missed my edit....
        Have a look here...
        • #19
          tried that and it still did not work, got to say that is a great web-sit though. if you look at the 1st photo i think the censor that i'm refuring to is the one you can just see to the right of the air filter on a short metal bracket.
          • #20
            thanks tony .was i thinking of an earlier engine then.
            www.overfab.uk
