Hey... so here is canada is started to snow today,
perfect time with icy hills to find out that your
ADD system seem to be dead. Heres whats happening
So you click the button on the 4WD stick and it does
not light up nor does the dash board.
Leave it in for a bit a drive still nothing, and i have of course used the 4WD before, about a month ago.
Other info that might help: E-brake light was on for the longest time even though the E-brake was out. sourced the problem back to ether Vacuum pump or the vacuum tank. Did not fix it cause of time and money. had been on for 3 or 4 month until a few days ago when it stopped what it was doing.
What i think its that cause the systems both use the Vacuum to work (brakes being Vacuum as a back up) is the ether the tank or the pump has kicked it.
What do you guys think? also i might need part number if you got any. Toyota Factory Part number would work best
Thanks
Thanks
