I am having a cold start issue with my 2LTE. I have changed the glow plugs and checked the fuses and all seems fine. The problem seems to be the cold. It will not start after sitting over night in below freezing temps(even with a circ heater and battery blanket). I can get it to run but it needs a warm garage and a lot of encouragement. Very tough to get fuel to the injectors. Once it starts it is fine and runs great. I thick it is the injector pump but want to be certain due to the high price of replacing it. The pump shows no sign of leaks.
Any ideas?
I have searched you site but have not found the exact same problem.
Any ideas?
