2LT Pistons & Cylinder questions
  • 2LT Pistons & Cylinder questions
    Howdy mates:
    dismantled the Mk1 2LT - no.4 piston has chunk chewed off just above no.1 compression - no.1 compression broke / also very worn - 3mm wide groove .15mm deep - have yet to check ridge at bottom
    already been bored to .5 over - correct to say cylinder cannot be replaced , yes ?
    Anyone have experience with rebore and sleeving - not sure if punching out to 1.m is the way to go
    What of aftermarket pistons - are there any as good as Toyota quality ?
    What of rings ? a better quality
    dunno if the Mk1 is still even driven on your side of pond - are pistons same in Mk1 as to Mk2?
    Cheers:
    According to the original Toyota manual, if the bore is oversizes by more tham 0.5, then replace the block.
    I don't know of any aftermarket piston and ring sets, but it may be cheaper in the long run just to replace the engine.
    Rob
    Still working for the man!
      According to rumours you can re-sleeve Speak to STEVO
        He's in Oz (at least I think he is), so might be best to email or post up for him, as it could be dear on phone calls.
        Here's a link to his contact details,
        http://www.hiluxsurf.co.uk/members_p...evo/index.html
        Couldn't find an email, apart from the user cp, but I'm not sure if it will work for non-paid up members, so I guess it's a telephone call then.
        Rob
          my faulty memory tells me Arizona....
            Howdy Mates:
            cheers for the info
            nope - Desert Southwest USA - Is confusing a bit - as Toyota sells 1.0 over pistons
            these engines were only available in North America for 3 years - possible one more in Canada - so not allot of pickings here - and chances are what is available from salvage is in worse shape than mine-
            Will seek out stevo and see what all I can find - prefer to sleeve/ re cylinder one than punch out 4 - new pistons of course
            Sure you'll hear all about it
            Cheers:
              howdy Sancho:
              Right on mate - Arizona - Sonoran Desert
              cheers:
