My 2.4 surf is kicking out a lot of black smoke when accelerating I have renewed the air filter and injectors, it’s just done over 200k, but this has not cured the problem
Could this be the turbo at fault?
have you disconnected the egr valve and blocked off the pipe do a search for egr and the instruction on how to do it will be there.
cheers shaun
I fitted new injectors (thanks diesel bob) replaced the fuel filter and run regular diesel. I have disconnected the egr valve but not fitted a blanking plate, a job for tomorrow I think
Thanks for the info
