First appologies for my mechanical ignorance.
We have a 'J' Surf with a 2.4LTD which is leaking diesel and letting air into the fuel system making it a pain to start. I can see where the diesel is
coming from but I don't know what it is called.
Looking from the front on the right/front side of the block there is a rectangular 'box' with a allen headed screw at each corner. On the top there is a 'valve' with a spring and a ball inside and also a electrical 'sensor'. The diesel is leaking from the large nut which holds the 'sensor' in place. We have undone the nut, there is a locking washer/flange underneath but no kind of seal or gasket etc.
What is this box?
Any suggestions on a fix?
Thanks
Ian.
What is this box?
Thanks
Ian.
