glow plugs
  • glow plugs
    hi could someone please tell me how to change the glow plugs on 2.4 surf cheers
    First you need to remove the top nuts off the plugs themselves, this allows you to get the joining plate wire, power supply off them. Then either a socket of spanner to undo the plug itself, (like spark plugs to a degree), then reverse the process for fitting again
    Without Surf And Unhappy
      Just replaced mine the other day. Invest in a set of long-sockets (12mm ?) drivers... or you'll be stuck doing 1/16 turns with a spanner!
        Every time someone asks about glow plugs i have to have a look back and giggle at this thread http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=30234
        =SOLD UP!=
          Thats just plain nasty. Fancy reminding everybody
          My other cars a QUAD
          (sv1000spilot on surf forums)
            that thread was soooo funny thanks for bringing it to my attention .
              i must've read it a dozen times and i still nearly spat my coffee over the keyboard reading it again.
              =SOLD UP!=
                thats just had me in stiches
                  Ok, so if youhave read this entire thread, and the one that Nero highlighted, your first action should be to make sure you know the difference between glow plugs, and injectors, and DO-NOT touch the latter
                  Rob
                  Still working for the man!
                    Check this link, and go to 3rd from last, download it ( will take 10 mins or so ) and you'll have the Toyota technicians manual, with step by step instructions, hope this helps.
                    ftp://ftp.bauchan.org/Toyota/repair_manuals/
                    Rob
