hi could someone please tell me how to change the glow plugs on 2.4 surf cheers
glow plugs
First you need to remove the top nuts off the plugs themselves, this allows you to get the joining plate wire, power supply off them. Then either a socket of spanner to undo the plug itself, (like spark plugs to a degree), then reverse the process for fitting againOriginally posted by nedhi could someone please tell me how to change the glow plugs on 2.4 surf cheers
Without Surf And Unhappy
Every time someone asks about glow plugs i have to have a look back and giggle at this thread http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=30234=========
=SOLD UP!=
Thats just plain nasty. Fancy reminding everybodyOriginally posted by nero279Every time someone asks about glow plugs i have to have a look back and giggle at this thread http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=30234
My other cars a QUAD
(sv1000spilot on surf forums)
thats just had me in stiches
Ok, so if youhave read this entire thread, and the one that Nero highlighted, your first action should be to make sure you know the difference between glow plugs, and injectors, and DO-NOT touch the latter
Rob
Still working for the man!
Check this link, and go to 3rd from last, download it ( will take 10 mins or so ) and you'll have the Toyota technicians manual, with step by step instructions, hope this helps.
ftp://ftp.bauchan.org/Toyota/repair_manuals/Rob
