hey guys
wonderin if u could help me i own a 1991 surf LN130 chassis with the 2L TE motor it all started when i decided to run it on veg oil and i think it has gone very wrong
i was driving around 1 nite and the proformance was very bad so i decided to put some diesel in and it helped for a bit till i was driving down the road and it just stopped dident splutter or anything just stopped like its an electrical problem the next day i drained the tank put fresh fuel in and replaced filter bled system up and went to start it and it dident go so i cracked the injectors open and cranked it and no fuel came out so then i cracked the pipes on the back of the pump but no fuel came out could this be the solinoid playing up and if so where is it and where does it get its feed of power from many thanks lewis
