hilux keeps getting stuck in park
  • hilux keeps getting stuck in park
    Hi we have recently bought a Hilux Surf ssr-x 2.4, 1992 - it keeps getting stuck in park!!
    Seems to be related to the 4x4 stick??
    Any advice would be really appreciated as we're new to all this!!
    Thank you
    Make sure the 4x4 lever is pushed fully forward.
      Fully backward for normal driving!
      Also, there is a solenoid that locks the transmission lever in Park until you press the brake pedal. You should be able to hear a little "thunk" noise when you press the brake in park. If that's stuck or dead, you can use the little red button to get out of park.
        Also, there is a solenoid that locks the transmission level in Park until you press the brake pedal. You should be able to hear a little "thunk" noise when you press the brake in park. If that's stuck or dead, you can use the little red button to get out of park.
        yes the little red button, what does that do
        Without Surf And Unhappy
          NUKE!
            Dont give anymore help to this person as he only logs on when bobdobs logs off
