hi my surf engine has jammed solid after some clattering so it has slipped timming or dropped a valve or who knows as timming belt is still on is this common with this engines also will a head from non turbo hilux fit or even bottom end if thats the prob thanks andrew
engine prob 2.4
Originally posted by adm123westhi my surf engine has jammed solid after some clattering so it has slipped timming or dropped a valve or who knows as timming belt is still on is this common with this engines also will a head from non turbo hilux fit or even bottom end if thats the prob thanks andrew
How do you know the timing belt is still on, have you removed the front cover?
Take the head off.
Any debris in the cylinders? Smashed heads and pistons? If so, it's knackered, easiest to get a new engine.
Otherwise,
Look for water in the cylinders (doesn't take much -- a few cc). If you're lucky you won't have bent a con-rod. Water in cylinders = blown head or head gasket = rebuild
If no water, try turning over (by hand). No luck = seized pistons = rebuild.Last edited by cataclysm; 1 November 2007, 10:09.
Not any more common than any other engine of this vintageOriginally posted by adm123westis this common with this engines
I wouldn't think so..... did they do a 2.4 normally asperated hilux?Originally posted by adm123westalso will a head from non turbo hilux fit or even bottom end if thats the prob thanks andrewBring me the head of a treehugger
Originally posted by adm123westBUSHWHACKER you being serious any good
Yep, the engine was running fine before I took it out, I've fitted a Lexus V8 now.
The 2.4 engine has been fine for the four years since I've had it, it's done 96,000 kms. I think the head has been changed in the past, but I can't confirm this, although there is evidence that the head has been off or replaced at some point, probably by the previous UK owner, (I'm the second)but he has emigrated now!
I bought it as a part ex. from a prestiege car dealer who only had it for a week.
It's listed in the parts for sale section.
