need to replace upper ball joint
  • need to replace upper ball joint
    Hi I need to replace both my upper ball joints, Is this a tough job and does anyone have any instructions or diagrams. I was thinking of doing it myself at the weekend.
    the upper ball joints are easy enough to do but you may well need to get new bolts for them as the old studs will be solid.4 Bolts on each ypper ball joint.You should be able to get both done within the hour no probs if you do get new bolts
      but does anyone have any diagrams or photos?
        heres some pics from when i fitted ball joint spacers.They're not in any order but you should be able to see what needs doing
        http://smg.photobucket.com/albums/v6...int%20spacers/
          I just talked to Toyota and they said they have a listing for 2 different ball joints for the left and right. Anyone have any info on this.
            the upper ball joints will fit either side.Check here at roughtrax
            http://www.toyotahilux.com/?doc=11&cid=146
              yup, toy part # RH is 43350-39085, LH is 43360-39085
              they may well only be handed because they aren't sealed so it keeps the grease nipple/plug accessible, aftermarket ones such as the roughtrax ones http://www.toyotahilux.com/?doc=16&cid=146&vid=309 will be sealed and won't have grease nipples, therefore will be identical.
              =SOLD UP!=
                Cool, Thanks, that explains.
                  Upper ball joints £19.39 each from Milners (£16.50 +vat)
                  http://www.milneroffroad.com/LN130.htm#strg
                  Ian
                  One day my paranoia will go away!
                    I orderd two from auto supplys in ireland for €60 for the two. Milners was €77 inc shipping to ireland.
                    C
                      Where in Ireland are you?
                        I live on the edge of Dublin and Wicklow but the surf loves to go into the Wicklow Mts at the weekend.
