Hi I need to replace both my upper ball joints, Is this a tough job and does anyone have any instructions or diagrams. I was thinking of doing it myself at the weekend.
need to replace upper ball joint
the upper ball joints are easy enough to do but you may well need to get new bolts for them as the old studs will be solid.4 Bolts on each ypper ball joint.You should be able to get both done within the hour no probs if you do get new boltsOriginally posted by irishoffroadHi I need to replace both my upper ball joints, Is this a tough job and does anyone have any instructions or diagrams. I was thinking of doing it myself at the weekend.https://www.facebook.com/groups/henpals/
heres some pics from when i fitted ball joint spacers.They're not in any order but you should be able to see what needs doingOriginally posted by irishoffroadbut does anyone have any diagrams or photos?
http://smg.photobucket.com/albums/v6...int%20spacers/https://www.facebook.com/groups/henpals/
the upper ball joints will fit either side.Check here at roughtraxOriginally posted by irishoffroadI just talked to Toyota and they said they have a listing for 2 different ball joints for the left and right. Anyone have any info on this.
http://www.toyotahilux.com/?doc=11&cid=146https://www.facebook.com/groups/henpals/
yup, toy part # RH is 43350-39085, LH is 43360-39085
they may well only be handed because they aren't sealed so it keeps the grease nipple/plug accessible, aftermarket ones such as the roughtrax ones http://www.toyotahilux.com/?doc=16&cid=146&vid=309 will be sealed and won't have grease nipples, therefore will be identical.=========
=SOLD UP!=
Upper ball joints £19.39 each from Milners (£16.50 +vat)
http://www.milneroffroad.com/LN130.htm#strgIan
One day my paranoia will go away!
