Oil leak
  • Oil leak
    Every time I change the oil I have a small leak from the nut in the sump, I have to tighten it up a bit more a few days later to stop the leak.How tight should it be and can I overtighten it with a 12" long wrench handle?
    You should replace the fibre washer on the plug each time you change the oil. That should stop any leaks.
    Mike G
      but can I over tighten, the seal is fairly new and looked good.
        You can overtigthen, and the seal has probably lost its integrity, shouldnt have to do it up really tight, i just tighten with rachet handle until it stops and give it a quarter to half a turn, otherwise you could strip the threads, or crack the sump
        Without Surf And Unhappy
