2.4 Revving to maximum and can't stop
  • 2.4 Revving to maximum and can't stop
    I have a K reg 2.4 Surf each time I start it the revs go to maximum, sometimes it will tick over ok until I touch the throttle then it just goes straight up to red line.
    Also the ECU fuse blows everytime I turn on the ignition but even with the fuse blown it behaves in exactly the same way.
    I have got an OBD code of six flashes.
    If anyone can help please reply here or to [email protected]
    Hi and welcome, code 6 is pump speed, according to this link (right at the bottom)
    http://www.toyotasurf.asn.au/techsite/efifaultcodes.htm
    http://www.off-road.com/toyota/tech/codes/index.html
    Rob
    Still working for the man!
      Thanks for the link
      I have looked but there doesn't seem to be much there that would cause my problem.
        have a look at the tps switch,this may be at fault.
        www.overfab.uk
          I've already replied on the other forum!
            Hi We disconnected the TPS and it is still doing it.
            Thanks for the reply though it is good to know help can be found here
              It does sound like an electrical problem, but sometimes a knackered oil seal between the pistons and cylinder walls can cause lubricating oil to be pumped into the combustion chamber and burnt. Has happened on a couple of old LRs.
              You'll know it's this if the exhaust is really smoky and the engine's eating oil.
              Totally screwed injectors might also do the same.
                other forum?????
                www.overfab.uk
                  other forum?????
                  It's where I talk Celicas.
                  There's a Surf section too.
                  http://www.toyotaownersclub.com/forums/
