Good day people, I've got a Denso A/C compressor that I intend to use for an onboard air system for tyre inflation etc.
I believe the pump to be from the 2.4 so that's why I'm posting in here!
I know all that I need to do to make the air system up, but I have a problem - the pump has no hose attachments included, and they're not typical screw-in ones so I'll need to source some 'yota ones.
Here's what the label says:
10PA 17C 147200- 4080 (I think this line refers to working pressure which appears to be about 14.7BAR)
R-12 ND-OIL 6 5L 3480 (Something to do with the refrigerant, and system capacity?)
LEAKAGE TEST: High side 30kg/cm^2
Low side 15kg/cm^2
The holes are appx 17mm and 20mm at the top, tapering down with stepping, looks like a push-fit hose held down by one bolt-clamp per hose.
Here's a pic of it as bought off ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=001
Any help is greatly appreciated!
Tom.
Low side 15kg/cm^2
Tom.
