Anyone ever heard a rattle noise coming from the rear of the surf - only now and then, heard a slight one other day but not today, and did'n happen just once yesterday couple of times over different periods, like a coin on metal tray sort of sound??
Rattle?
Originally posted by SmilerAnyone ever heard a rattle noise coming from the rear of the surf - only now and then, heard a slight one other day but not today, and did'n happen just once yesterday couple of times over different periods, like a coin on metal tray sort of sound??https://www.facebook.com/groups/henpals/
Originally posted by Smilerdoes it need to be replaced asap? And if so where abouts on the ca are they? thanks
if you look the thru the rear wheel arch you will see a drop link arm bolted to the chasis and follow that to where it joins the thick bar that runs along the axel and there should be 2 brackets that hold the bar onto the axel.I would post a pic but i have taken my anti roll bars off of mine
if you check and require a bracket i have got 2 here you can have if needed
heres the link for the brackets and bushes if needed
http://www.toyotahilux.com/?doc=11&cid=162Last edited by stormforce; 18 September 2007, 22:09.https://www.facebook.com/groups/henpals/
Originally posted by SmilerI will check it out tomorrow and let you know how it goes, need to sort it i think as i am off roading on saturday for the first time....https://www.facebook.com/groups/henpals/
