I need to replace my broken radio antenna mast. The plastic cable is broken, so I need to open the antenna motor and pull out the broken piece. I know where it is and how to do it. HERE IS THE PROBLEM.... How do you get the liner off of the inside of the wheel arch. I removed 4-5 screws, but there seems to be rivets holding it as well. What is the "trick" to getting the lining out?
Thanks!
Thanks!
