Greetings all
I have an annoying recurrent problem with my 2.4 ssrx 1992 diesel surf. Some time ago I was returning home on the motorway when both eng check lt and turbo lt came on. Working on the principle of if it still runs then keep running, I plodded on at a racy 40 mph (as that is all it would do - even less uphill) for 40 miles when everything became good again and the lights went out. Shortly after that on initial start every morning it would start and immediately cut out unless revved. If you then push the ignition key in and out a couple of times it runs fine for quite some time, but at completely random occasions when the revs hit 600 or lower it will cut out again. Imagine the fun I have when slowing down behind a middle lane driver on the motorway or at rush hour going round a roundabout- the school run mum loves me lots!!
I have done a diagnostic and got the number 12 - timer control valve. I have since reset everything but whenever it cuts out there is nothing on the diagnostics. Could it be the pump or maybe the ignition barrel. Any pointers would be much appreciated. This will make you laugh - I took the beast to the local toyota agent.....????????!!!!!!!! Useless
