Whilst out and about today, I returned to my car (1993 2.4 Surf )which had been runing perfectly and when starting, it drove very sluggishly with the turbo light off and not able to get much above 50mph. I know from other posts that this is a turbocharger problem although the suddeness of the change in performance was amazing.
My real question is this...
When I opened up the bonnet the air intake pipe was broken, this must have happened some time ago as it was a complete break not a crack. So would the lack of air flow have caused this problem with the charger or is it that the charger has become full of rubbish it shouldn't have? Does it have a seperate air filter on the unit? Is this a simple matter of filter cleaning and replacing pipes or an expensive garage job.
As you can tell, not into home car repairs other than the most simple, so all help and advice much appreciated. Thanks
